Minneapolis Moline Tractors Discussion Forum
Hand contols on Tel-O-Flo removal
herald
04-16-2007 09:32:12
On a 5 Star Tel-O-Flo Hydraulic system, to replace the"O" ring seals on the hand control levers, if you take the 2 bolts out on the quadrant housing and the anchor bolt, shouldn't the hand levers slide out? These don't. Am I missing something? Any ideas? Thanks, Harold
4molines
04-16-2007 14:45:41
 Re: Hand contols on Tel-O-Flo removal in reply to herald, 04-16-2007 09:32:12
On Jetstar3, have to take top square plate off.
Inside shaft is pinned to spool actuator.
Believe they're all like that
04-17-2007 04:39:35
 Re: Hand contols on Tel-O-Flo removal in reply to 4molines, 04-16-2007 14:45:41
Bt removing that pin I won't get anything "out of time" will I? On my 670, they just slide out, maybe something is missing on the 670? "Thanks for your hel[p. Harold
T.R.K.
04-18-2007 19:29:27
 Re: Hand contols on Tel-O-Flo removal in reply to [email protected], 04-17-2007 04:39:35
I think you need to look at an exploded view for your particular hydraulic system.
If its made like the one I had apart (1958 335) I don't think you could get the little levers off the inner end of the control lever shafts and back together (Its only a 2" x 3" or so hole in the top there.) without taking the whole control valve assembly apart.
herald
04-18-2007 20:30:07
 Re: Hand contols on Tel-O-Flo removal in reply to T.R.K., 04-18-2007 19:29:27
I think your are right,they have to be taken apart on the inside. Next winter I'll tackle that. Thanks for your imput.
