Minneapolis Moline Tractors Discussion Forum
Removing the grill on a Big-Mo 500
wcs
04-13-2007 09:39:42
I need to replace the raidator on my Big Mo 500. It has a L500 loader and the big cast grill. Anyone have a suggestion on the best way to pull it out? Are the 4 bolts on the lower front of the grill the ones that hold the grill on? Also will the hubs off a jetstar 2 work on a big mo?
Thanks Chris
T.R.K.
04-13-2007 18:28:50
 Re: Removing the grill on a Big-Mo 500 in reply to wcs, 04-13-2007 09:39:42
Be careful. Company advertisements said that cast grille weighs 700 or 800 lbs.
The 445 grille uses those 4 bolts on the front. It may also use 3/8 bolts in the sides or have support to the 3 tapped holes in each side of the front bolster. I do not know on a Mo500.
I am pretty sure the hubs from a Jet2 will work but the bearings in them may not.
