Minneapolis Moline Tractors Discussion Forum
electrical problem
Brian(MN)
04-12-2007 16:41:21
Hi, Maybe you guys can give me some advice. My U302 quit generating. I had put a new alternator, and regulator on it and used it for half a year, it worked great. Then last fall it just quit generating and I can't get it to work. Gauge works as I can see it discharges and the battery is slowly drained. Any way I can check the system and figure out what is wrong?
Thanks in advance,
Brian(MN)
Jossette
04-12-2007 19:33:49
 Re: electrical problem in reply to Brian(MN), 04-12-2007 16:41:21
Wenzel electric in Mankato will fix you up. Rebuild it on the spot or get one coming. Good people. Bought a delco 3 years ago and the internal reg went out and they put one in free of charge. Heck of a warrenty policy...
Tj in iowa
04-12-2007 18:43:10
You can check to see if it is charging with a voltmeter, it should be 13-14 or so volts at the battery. If you still have problems I recommend a Delco-tron alternator with an internal regulator, which always work better that any generator ever did. If you know where there is an old Chevy pickup or car you can rob it off there, or they don't cost too much if you buy a rebuilt unit at Napa or something. Let me know if you have questions
T.R.K.
04-12-2007 18:35:47
Brian,
I assume it is the original-type Delco alternator that uses a separate regulator. I worked on one once that had problems with the regulator housing being properly grounded. The regulator was in a rubber mount and the ground that jumped the rubber straps was no longer doing its job. Check that and also the mounting bolts.
If yours has a later alternator with internal regulator, you are on your own.
Brian(MN)
04-12-2007 19:37:09
 Re: electrical problem in reply to T.R.K., 04-12-2007 18:35:47
You are correct, they are seperate.
Brian(MN)
Bob
04-12-2007 22:34:50
 Re: electrical problem in reply to Brian(MN), 04-12-2007 19:37:09
"Full-field" the alternator by putting battery voltage direct to it's terminal labeled "F".
(Since this is an EXTERNALLY regulated alternator.)
If it charges like crazy while "full-fielded, but NOT when connected to the voltage regulator you have a regulator or wiring problem.g
If it DOESN'T charge, you have an alternator problem.
Brian(MN)
04-13-2007 17:58:00
 Re: electrical problem in reply to Bob, 04-12-2007 22:34:50
Thanks, I checked it your way and found out I had a bad regulator.
Brian(MN)
