Minneapolis Moline Tractors Discussion Forum
Minneapolis moline help identifying
Dalejn7
04-11-2007 15:47:23
I have a tractor that says model UTIL s/n 0144900321 on one tag. On another tag it has model 4 1/4 X 5283A4 S/N 0194903727. Also has a loader that says Reese Enginering Co. Mod C-100 load limit 6,000 LBS. The only MMs that i can find listed that seem close to mine are model 335 or 445 utilitys but mine seems to have to many numbers in the s/n.This is a big tractor with no power steering.Also no draw bar or power take off.It is a 4cyl. gas Any help apreciated.
herald
04-11-2007 21:16:12
 Re: Minneapolis moline help identifying in reply to Dalejn7, 04-11-2007 15:47:23
According to my book, it is a 1949. They were produced from 1946-1957. In 1949 the serial numbers started with 014490001 and ended with 0144900340. The prefix 014 indicates Type283A-4 engine. Hope this helps.
molinebob
04-11-2007 18:07:25
I just went through my manual on MM tractors, and the other plate that says 4 1/4 x 5283A4 is the engine tag, it is a four cylinder with a 4 1/4" bore 283 ci and the s/n that follows id the s/n for the engine, I think that yours is newer than a 1950 but the letter code is as follows, U- next biggest tractor in the series, second biggest rated at 40 hp
T- stands for tractor
I- stands for industrial, heavier built standard version
and the fourth letter stands another option such as It might be that it has a lighter on it or possibly live hydraulics
I'm not sure on the year my one manual goes from 1940-1955 and there is a reference in the other manual listing it as a 1939 model but that manual only goes up to 1950, so your guess is as good as mine on the year of it.
Jim Parisot
04-11-2007 17:51:55
Dalejn7,
Well, if it says model UTIL and has a serial number following that, why would you think it is anything but a UTIL? The serial number is consistent with one manufactured in the 1949 model year, being #321 of 340 made. The engine is also consistent with 1949 manufacture and is the correct 283 engine. This tractor is the industial model of the U and the L indicates it has the shuttle shift, meaning you will have the normal foot clutch of an industrial U (UTI) and a hand lever for the shuttle in the normal location of a U hand clutch. Having a loader on a UTIL is very common, some people say the L stands for loader, the shuttle shift made it convenient to use in the constant back and forth movement of a loader tractor. If you were to describe your tractor to use thoroughly and left out the serial numbers it would be pretty easy to peg it as a UTIL. Hope this helps.
Jim
Dalejn7
04-12-2007 08:16:08
 Re: Minneapolis moline help identifying in reply to Jim Parisot, 04-11-2007 17:51:55
Thanks, this really helped. When I looked up all the models of MM"s, there was a 335 and 445 utilty listed but there wasn"t any model util. Do you know where I can get an air cleaner top for this tractor? It runs good, but that is the only thing missing from it. Thanks again for your help with this, Dale.
