Minneapolis Moline Tractors Discussion Forum
RTU Engine Compression Numbers
Jim/41_9N
04-02-2007 16:47:22
Anybody know what kind of compression results should be expected from this tractor? Minimum spec?
Thanks,
Jim
Augie
04-02-2007 21:00:36
 Re: RTU Engine Compression Numbers in reply to Jim/41_9N, 04-02-2007 16:47:22
Depends on which head, how many cubes, cam grind etc.
My 228cid ZA motor with a 10A2648 head is right at 170psi at cranking speed. If you're still at 165cid, the common RE226C head, and stock cam I'd guess in the neighborhood of 90-110psi. Hopefully somebody who has pumped one will chime in later.
