Minneapolis Moline Tractors Discussion Forum
getting steering wheel off 670
herald
03-26-2007 10:09:02
Any ideas on getting the steering wheel off on a Super 670? I've already broke my little puller trying. Any suggestions would be welcome.
m+j farms
03-30-2007 19:48:11
 Re: getting steering wheel off 670 in reply to herald, 03-26-2007 10:09:02
i took mine off a few months ago by using a bearing seperator under the wheel with a two jaw gear puller hooked to it. i drilled a hole in a 1x4 piece of hardwood then cut it in half to put under the wheel to keep from breaking the plastic put the bearing seperator under that to have a good surface to pull on and hooked my puller to the sides of the seperator. after it was cranked down good and tight i hit the end of it ( hex end of puller) with a hammer a couple times and screwed it in to pull it off. be carefull not to smash out the end of the shaft or pound too hard as it might break the box under the dash..
herald
04-03-2007 04:52:28
 Re: getting steering wheel off 670 in reply to m+j farms, 03-30-2007 19:48:11
m+j Thanks, finally got it with no damage to wheel. Harold
