Minneapolis Moline Tractors Discussion Forum
335 puller
Bobby McClain
03-25-2007 22:18:54
I have a 335 that I pull and I need to lighten it up by a 100 to 150 lbs to make it in the 3500 lbs class.My quistion is if I take out the pto clutch pack and pto shaft is it ok to pull it like that.
Thanks for any help or any Ideas of what else I can do to lighten it up.
ES
03-30-2007 10:15:07
 Re: 335 puller in reply to Bobby McClain, 03-25-2007 22:18:54
How well do you do in the classes you pull in? Have a 335 universal narrow front thinking of pulling? What tractors are you competing with?
Bobby McClain
03-27-2007 20:35:41
It is a utility model it has no hydraulics or three point on it.The front has been converted to a trycycle front end and I'm running 6.00x 14 three rib firestone tires. have some adapters on the rear wheels so I can use 15.5x38 rear tires.changed the hitch and removed the weight brackets.I pull here in Ky.thanks for the help. I got to figure out how to plug that hole in there now. Bobby.
Mopower
03-27-2007 20:16:00
My buddy had his down to 2596#. If yours is a utility, drop that heavy front axle and install the narrow front. There's plenty of other things too. Hydraulics (3pt) are heavy.
Chuck S.
03-27-2007 16:57:35
I pull a 335 in 3500 with about 190 lbs of front weight. What 335 are you pulling? Is it a utility or row crop? You can remove pto clutch pack and spline shaft the long shaft that drives the pto and hyd, but you will need to plug the t/a input shaft to keep the t/a and trans oil from leaking onto clutch. ALSO HAVE YOU REMOVED 3 PT AND HYD SYSTEM? By the way where are you pulling?
