Minneapolis Moline Tractors Discussion Forum
Correct motor carb for 1951 ZAU
Drew Halvorsen
03-23-2007 15:31:31
Hi Folks: Yes my parts catalog is in the mail. Checked moter s/n 01807399 3 5/8 x 5 (206B4) Carb. TSX97. Can we say that they are correct for the tractor? Also found that the wide front is apparently after market. Made by the Norden Axle Co. Russell, Kansas. Does anyone know the quality of same? Thanks for the time and efforts. Drew s/w WI.
T.R.K.
03-23-2007 18:19:33
 Re: Correct motor carb for 1951 ZAU in reply to Drew Halvorsen, 03-23-2007 15:31:31
Yes, the TSX 97 is the correct carburetor for your 206B-4 in a 1951 ZAU. The correct front end configuration for your tractor should have been 2 wheel narrow front. If your aftermarket axle is like a Schwartz, it probably has the original front pedestal on the tractor.
That said,My opinion is If you are happy with the front axle and it is in good condition, I wouldn't worry a whole lot about changing it.
