Minneapolis Moline Tractors Discussion Forum
Pressure checking heads
Molinegb
03-19-2007 17:54:24
How much pressure do you apply to properly check MM heads? I sold a set of 4209's to a guy,which said he had them pressure checked. He said they were no good. I took the heads off a 670LP I was using. I never had any problems with antifreeze in oil or overheating.
J Schwiebert
03-19-2007 18:36:18
 Re: Pressure checking heads in reply to Molinegb, 03-19-2007 17:54:24
I want to see what you get for answers. When I did some crack repair and diesel head classes I always tried to get 30 PSI. What kind of pressure tester are you refering to, plate type or individual disk (Irontite) type.? I only checked one set of Moline heads. They were for a G-1000 Diesel. They needed work. J.
