Minneapolis Moline Tractors Discussion Forum
RTU Fender Platform
Minicass
03-18-2007 18:08:36
I have a 1946 RTU. I found some fenders. My model should have extensions attached on the back platform. I do not have the extensions. This piece came off a MM, but we don't know what year/model. It fits my tractor, by replacing the existing platform, except the PTO cover won't go on. What tractor/year was this platform used? Should I hold out for original extensions on my tractor, or make this one work? Thanks.
www.cassphoto.com/mmplatform.jpg
Jim Parisot
03-21-2007 19:19:12
 Re: RTU Fender Platform in reply to Minicass, 03-18-2007 18:08:36
Minicass, I may be missing something here, but why don't you use the platform on your 46 RTU that you have pictured? Like T.R.K. said, it looks like an early R platform in which case you do not need extensions. The later platform was narrower and needed the extensions to get out to the dimension that the earlier ones had. Unless you are wanting to be politically correct (like me) that earlier platform should work. If you go the 3 piece platform route you will need the 2 brackets also. Hope this helps.
Jim
minicass
03-22-2007 06:31:26
 Re: RTU Fender Platform in reply to Jim Parisot, 03-21-2007 19:19:12
Jim, thanks for the reply. My 1946 has the narrow platform. Thanks to the replies on the forum, I found out the platform in the picture goes to an earlier model. I have decided not to use the wide platform, but try to find the appropriate extensions for my model.
www.cassphoto.com/fenderparts.jpg
Kevin Moschenrose
03-20-2007 07:35:51
I have the platform from a 48 model on a tractor I am parting out. More than likely it you would have as much in shipping on it from central Illinois.
minicass
03-20-2007 11:32:54
 Re: RTU Fender Platform in reply to Kevin Moschenrose, 03-20-2007 07:35:51
I have the platform for my tractor but do not have the extentions. Does the parts tractor have extensions? Depending on how much you want for them, shipping might be an option. I only need the extensions. Thanks.
Kevin Moschenrose
03-20-2007 22:53:07
 Re: RTU Fender Platform in reply to minicass, 03-20-2007 11:32:54
Yes they do have the extentions on it and I would sell just them if you want them.
T.R.K.
03-19-2007 07:48:30
The picture is of a platfor from a '39 or '40 model R. I have one like it on my '40 RTS. Later Rs used a 3-piece platform up until about 1950 when it was changed again. I have the 3-piece on a '48 model.
The PTO cover is a U-Shaped piece of sheetmetal that bolts to the platform. I am thinking it will be the same part that was used on a '39 or '40 U, but not a ZT part for some reason.
minicass
03-19-2007 08:21:00
 Re: RTU Fender Platform in reply to T.R.K., 03-19-2007 07:48:30
Thanks for identifying the platform! I think I will not use it, but try to find the correct extensions for my 46 model. I have the pto cover. Again, thanks for the responses!
Loren in MN
03-18-2007 23:21:07
I've never seen a platform like that one. The drawbar support looks like that of a Moline. I've got photos of what the platform should look like. Will this mount on your "R" -except for the PTO shield?
minicass
03-19-2007 05:05:43
 Re: RTU Fender Platform in reply to Loren in MN, 03-18-2007 23:21:07
Yes, it will mount on the tractor except for the pto. Could you send me the photos you have?
