Minneapolis Moline Tractors Discussion Forum
MM -Lull loader mounting?
Loren in MN
03-18-2007 09:22:17
Does anyone have any information on -How the hydraulic pump is mounted to the front of a "R" Moline for use with a Lull loader? I have a splined shaft bolted to the fan pulley, but I'm not sure what the mounting bracket for the pump looked like, or where it bolted onto the tractor. Anyone have info on what the pump and bracket looks like? Thanks.
G. L. Perry
03-18-2007 14:37:20
 Re: MM -Lull loader mounting? in reply to Loren in MN, 03-18-2007 09:22:17
I have a copy of manual for RTI with loader. No pix of mounting, other than line running, BUT, did have an engineering type blueprint for the mounting if you can read those OK. Just has side veiw, not top, but shows pulley, two shafts and couplers, and also the mount from pump body, with bracket off front of tractor. I can scan and email to you if you wish. Send your address to [email protected] and I'll send it out right away.
