Sorry it took so long. My 335 is a utility too, and I had to hunt for the drawbar. There is more to making one than I thought: 42-5/8" long, 1-1/4 thick, 2-1/2" wide dimensions from the front: The front hole is actually a 1" wide slot from 1-3/8 to 2-1/4 on centers. A 1" hole would probably work. The front is milled to 1-1/8 on the underside to 7" from the front. (so it fits in the yoke up there, I guess.) At 13" from front, it offsets 1/4" downward. The offset is complete (straightens back out) at 16-3/4 from the front. (I think this is so it clears something under the rear of the tractor.) At 32" from the front it offsets upwards 1-1/2". This bend is complete (straightens back out at 35-1/8" from the front. If you have real small tires-like 10" or so you will probably need this offset to get a realistic hitch pin height. The hitch pin hole is 39-1/2" from the front. 1-1/8 dia. There was another 3/4" or so hole 4-5" from the rear that I did not get the dimensions for. I don't ever use it. Another thing: you have to remove the drawbar to get full use of the 3 point. It sticks back 3-4 inches too far to keep it on the tractor. Hope this helps. Kelvin
