Minneapolis Moline Tractors Discussion Forum
G pistons in U block
David Jensen
03-09-2007 21:49:46
I was wondering if anyone could tell me if you can bore a utu block out and use a stock gb piston?
colby s
03-13-2007 18:42:05
 Re: G pistons in U block in reply to David Jensen, 03-09-2007 21:49:46
I just had my U blocks bored to 4.42. I have heard of people going to 4 and 9/16. But It is not possible to bore then to 4 and 5/8.
SWMolines
03-11-2007 07:12:43
The stock MM U block can safely be bored to 4-3/8". Some people will bore them slightly beyond that diameter. If you want to go to the 4-5/8 bore pistons, you"ll need to get blocks from a MM M5 or later gas tractor. Blocks from MM gas tractors with the 336 and 504 engines were all 4-5/8 bore.
