Minneapolis Moline Tractors Discussion Forum
LP TANK
TOWBOATT
03-09-2007 12:02:47
I AM NEW TO LP TRACTORS.I CHANGED OVER TO A FORK LIFT LP TANK ON MY GV1. I KNOW THAT THE FORK LIFT TANK ONLY HAS A LIQUID SUPPLY.NOW I SEE A LITTLE FROSTING UP AROUNG THE SUPPLY INLET ON THE REGULATOR. THE ENGINE STARTS AND RUNS OK. I GUESS MY QUESTING IS. WILL THIS FROSTING UP CAUSE PROBLEMS WITH THE REGULATOR OR IS THIS NORMAL? THANKS TONY
Curt Cooke
03-12-2007 08:18:39
 Re: LP TANK in reply to TOWBOATT, 03-09-2007 12:02:47
If by chance, it's an ensign regulator, they all form frost around the fuel inlet. I have Ensigns on my GB, my M5 and my UB Special. They all freeze around the fuel inlet. It's a handy fuel gauge. When you no longer see frost, you are running on vapor and had best head for the house.
LW
03-09-2007 18:56:05
Sounds like a small leak, If its a century regulator or some of the other that fitting is attached with two screws and has a seal sometimes you have to tighten up even the new ones. It could be where you line goes on. I have run pullers of those tanks for a long time never had a problem.
