Minneapolis Moline Tractors Discussion Forum
445 utility anyone within 150 mi of des moines
CALVY
03-06-2007 20:56:46
I AM LOOKING FOR A GASKET SET FOR THE REAR HYDRAULICS AND DIFFERENTIAL ON 445 MM UTILITY - WILL I HAVE TO MAKE THESE ? ALSO DOES ANY ONE DO REPAIR/REBUILD ON THE HYDRAULICS I HAVE IT OFF THE TRACTOR NOW TO REPLACE THE PTO SHAFT -IT WORKS BUT DROPS LIKE A ROCK AS SOON AS UP PRESSURE IS RELEASED I AM NEAR OSCEOLA IOWA MIGHT BE INTERESTED IN A PARTS TRACTOR ALSO
hd6gtom
03-14-2007 07:52:04
 Re: 445 utility anyone within 150 mi of des mo in reply to CALVY, 03-06-2007 20:56:46
Try Mease imp west of Truro Ia on the pavement. John still has a lot of MM parts and still works on a few.
garry lee
03-07-2007 06:27:49
i had to redo mine and got the parts from a local dealer that sells White tractors and equipment. AgcoAllis should have them as well. if you have a good repair manual you can do this work yourself.
