Minneapolis Moline Tractors Discussion Forum
MM Loader? on U302
Luke Miller
03-04-2007 19:06:02
I posted a picture of my loader on my U302 in the help identify gallery. I broke the cylinder for the bucket tilt when I picked up too big of a round bale. Can anyone tell me what model of MM loader this is, or if it is an Oliver/White or something else. Also if I can still find parts to fix the cylinders. I believe the loader came new on my 602 I had awhile back, but it has been on my 670 and now the 302 since. Any input would be great. Thanks
Luke Miller
03-06-2007 08:26:13
 Re: MM Loader? on U302 in reply to Luke Miller, 03-04-2007 19:06:02
Kevin, if you could scan that and send it I would appreciate it. I would just as soon get my parts from the local Agco dealer (if available). I thought it was a MM loader but had no idea if they had a model number for it so I could even look for parts. If all else fails I may put bigger cylinders on it since I can't go above MM's 1600 psi on the system (I dont think). To elaborate on the damage, the dust seal, snap ring, shaft seal, and what I believe is part of the piston came out of the end and also broke the ring that holds the end gland on the barrel. I cant push either of the cylinders back in by hand or by bouncing the blind end on the ground. I also have found some cracks in the frame work where it looks like it may have twisted it some. by the way Bill this is the loader the brackets for your 602 came off of. Thanks for all your help!
Glen in TX
03-05-2007 19:03:12
What exactly broke on it? Find a hydraulics specialty shop or machine shop that does hydraulic cylinder repairs and they can make or find most parts to fit or replace the cylinder also. If Schwartz made it and you just bent or broke the shaft give me measurements as I have some Schwartz cylinder shafts but that's all no other Schwartz parts.
Armand Tatro
03-05-2007 16:00:54
I compared your photo to our Oliver 1610 and it appears to be the same(99.9%sure).It would appear that Oliver and M&M brought the same loader and painted them their colors and added their logo. I used a M&M.1610 mounted on I think it was an M5. The logo and colors were M&M. Armand
Kevin Moschenrose
03-04-2007 20:38:24
That is an L-800 loader made by Swartz for MM. Swartz also made it for Oliver as well but I don't know the model of that one.I have a parts book around here some place for one that I got for mine, so if you need it scanned let me know. I'll see what I can come up with.
Bill Becker
03-05-2007 10:44:59
 Re: MM Loader? on U302 in reply to Kevin Moschenrose, 03-04-2007 20:38:24
I have an Oliver loader on an M602 and the model is 1610
