Minneapolis Moline Tractors Discussion Forum
335 king pin kit
Bruce Mitchell
03-04-2007 17:15:42
I have a 335 with industrial front axle,solid beam.Does anyone have a part # for a king pin and bushing kit.TRW ,MOOG, etc.Thanks for any help
T.R.K.
03-05-2007 18:08:57
 Re: 335 king pin kit in reply to Bruce Mitchell, 03-04-2007 17:15:42
I put a NAPA 262-1307 king bolt kit in both a ZAS with Agricultural axle and another ZAS that had a ZASI industrial axle. I did have to grind the retaining pin slot about .060 deeper in these pins, but they seem to be working O.K.
I am thinking the RTI used the same front axle as this ZAS that is equipped with the ZASI front axle. (The casting numbers start with 'RT') and I read somewhere that the 335I used the RTI front axle. But you better get one of the freeze plugs out of yours and check. The NAPA catalog says the pins are 1.124 dia.
If you need to know: The book says the kit has two 262-8056 bushings and two 262-8057 bushings.
Yugrotcart
03-05-2007 15:38:13
Bruce,
I had an MM Z that needed king pins. New ones weren't avaliable. Measured the old ones and made my own. Went to the bearing store and picked up the poper size bushings. Worked well.
Just a thought if you get stuck.
Paul
