Minneapolis Moline Tractors Discussion Forum
MM Blocks
Richard Avila
03-03-2007 13:02:20
Will M blocks and pistons fit ok on MM-U Lp.
MnM44
03-05-2007 10:49:28
 Re: MM Blocks in reply to Richard Avila, 03-03-2007 13:02:20
Yes the M5 or 670 blocks will fit the pistons are taller though and you either need to machine off the top of the piston or add block gaskets to make up the difference.
PGpower
03-03-2007 18:42:03
M5 or any other blocks/pistons will fit on a U...takes the U from 283 cu in to 336.
PGpower
03-03-2007 18:42:57
 Re: MM Blocks in reply to PGpower, 03-03-2007 18:42:03
I meant to say that M5 or any other 336 block will fit on a U.
Richard Avila
03-05-2007 11:42:12
 Re: MM Blocks in reply to PGpower, 03-03-2007 18:42:57
Thank you for the information about the MM blocks.
