Plow question
Brian
01-03-2000 17:14:56
i found a plow in a old barn and like to restore it and use it someday!there is no serial no. tag on it anywheres that i can see.it is a light red and yellow rims the moldboards are the light red to.the only imformation on the plow is on the frame is stamped Moline v5018.it has 2 levers for leveling the plow and the rope to drop the plow in the ground.the one rubber tire wheel has the clutch to raise the plow out of the groung.it is a pull type plow.can anyone tell me what model it is or what year it is. i measured the moldboards they where 14 inches if anyone has any imfo on this plow. please share it with me or net sites to get the imfo.i would like to thank you for your time Brian,Wis
Martin A. Johnson
01-03-2000 20:22:21
 Re: plow question in reply to Brian, 01-03-2000 17:14:56
sounds like the typical MM pull type plow, mabey an "AF" built in the 40's & into the 50's. I have two of these, both 3 bottom, one hyd. lift, that my grandpa bought new & the other a mechanical lift. I got from a dear friend. MAJ
