Minneapolis Moline Tractors Discussion Forum
707 hydraulic filter?
Moline_guy
02-28-2007 09:20:38
Do the 705 and 707 have a hydraulic filter in the reservoir? Got an I & T book for the G1000 but not the older 70 models. I am guessing its in there just wanted to know before i tear it apart. Thanks for any replies.
Curt Cooke
03-02-2007 13:20:24
 Re: 707 hydraulic filter? in reply to Moline_guy, 02-28-2007 09:20:38
The 705's, of which I have 2, came with two different types of hydraulic set-ups. If you have the type with the solid square "hydraulic box" under the seat, the filter is obvious - lying horizontally held in place by a large cap with a hex nut on it on the right side. That cap is about 4 inches in diameter. If you have the other type where there's a hydrualic tank mounted inside a steel square cage that supports the seat, all you get is a strainer which is located inside that resevoir and it looks similar to the crankcase oil pick up on an R or Z and it's difficult to get to.
