Minneapolis Moline Tractors Discussion Forum
ensign carb
minnesota steve
02-23-2007 09:42:23
I have an old ensign updraft carb that looks like it was for propane? , it is the same color as a mpls moline, does anyone know anything about these? it looks and feels like it is all brass? with a threaded port about 3/4 pipe on the bottom any help at all would be great
thank you
Ill John
02-25-2007 14:43:27
 Re: ensign carb in reply to minnesota steve, 02-23-2007 09:42:23
Steve, Sounds like a LP carb. The distance between the mounting studs might give us a clue as to what size engine it would fit. Don't have picture capability or I'd post a picture on here. John
minnesota steve
02-26-2007 14:49:44
 Re: ensign carb in reply to Ill John, 02-25-2007 14:43:27
the distance between the studs is 2 3/4 inches
the throat is stamped 1 1/4 3 ports are marked A: 1/8th inch pipe thread at top of throat
B: 1/8th inch pipe thread with jet at air intake
C: 3/4 inch pipe directly across from air intake
tag on carb says 10a over 1786
I hope this helps
