Minneapolis Moline Tractors Discussion Forum
MM Z s/n
Drew Halvorsen
02-21-2007 20:51:41
Hi Folks: Recently bought a MM Z l949 Model. The serial number plate say Z---- Most of the manual ect. indicate Z with letters following. How do I determine what letters follow my serial number. I will thank you for your time and efforts in advance. Drew s/w WI.
Jim Parisot
02-22-2007 16:33:50
 Re: MM Z s/n in reply to Drew Halvorsen, 02-21-2007 20:51:41
Drew,the letters following the Z simply designate front end configuration. If your serial number starts with 00649 you have a ZAU - two front tires spaced close together (Universal). 00749 would be a ZAS - none adjustable wide front (Standard). 00849 would be a ZAN - single front wheel (Narrow), and 00949 would be a ZAE - adjustable wide front (Extendable). Hope this helps.
Jim
Drew Halvorsen
02-23-2007 15:28:28
 Re: MM Z s/n in reply to Jim Parisot, 02-22-2007 16:33:50
Thanks Jim.
