Minneapolis Moline Tractors Discussion Forum
MM U alternator big enough?
davids
02-15-2007 18:17:06
Recently changed from generator to alternator on a propane MM "U". A motorola alt. that came from a 450 JD dozer. At idle she makes about 7 amps. and about 15 amps with throttle opened up. It this enough to run the ignition and charge the battery too or do I need to get something bigger? Thanks, davids
Bob M
02-16-2007 06:01:55
 Re: MM U alternator big enough? in reply to davids, 02-15-2007 18:17:06
That Motorola alternator should be more than adequate to supply your U's electrical needs!
Keep in mind the alternator's output depends on the battery's charge level. When the battery is down (ie. immediately after cranking) it should charge near the max the output of the alternator - probably 30 amps for your alternator. However as the battery reaches full charge output will taper off and stabilize around 2 - 4 amps.
Keep in mind also the original generator on the U maxed out around 15 amps at 6 volts. That's HALF the wattage (power equivalent) of the 15 amps at 12 volts you're getting now with the alternator!!
T.R.K.
02-15-2007 18:40:07
It should be. Don't know how you wired it, but I don't see the old generators putting out much more than 7 amps.
davids
02-15-2007 18:56:51
 Re: MM U alternator big enough? in reply to T.R.K., 02-15-2007 18:40:07
I used the hot wire that fed the regulator for the main wire and ran a wire from the switch to the excitor wire to activate it. Power still runs through the gauge and shows 14.2 volts at the battery. Thanks, davids
Springdale
02-20-2007 02:05:29
 Re: MM U alternator big enough? in reply to davids, 02-15-2007 18:56:51
davids,
Just keep an eye on the battery voltage from time to time. 14.2 is overcharging if the motor is not running, but not a bad running voltage.
Watch the water level, too. Or add a voltmeter if you really want to keep an eye on things.
