Minneapolis Moline Tractors Discussion Forum
445 mm 3 point drops like a rock
kevin sturtz
02-11-2007 09:01:02
3 pt lifts stays up ok if i hold lever back but drops like a rock if not . is this an easy diagnosis - as far as what needs repaired . i am replacing the pto shaft so i will have things apart and would like to get this fixed at that time.
JK2
02-12-2007 04:58:41
 Re: 445 mm 3 point drops like a rock in reply to kevin sturtz, 02-11-2007 09:01:02
Either the 3 pt spool is not syncronized with the master spool or the rings/cylinder are damaged allowing fluid to leak past the rings.
