Minneapolis Moline Tractors Discussion Forum
445 Crankshaft
G Brown
02-11-2007 07:53:14
Can anyone tell me if a 445 crank and Jetstar 3 are the same? I know a U302 is the same. I'm looking for a 10B20411 crank in good condition.
G Brown
02-12-2007 05:28:27
 Re: 445 Crankshaft in reply to G Brown, 02-11-2007 07:53:14
Also going to need crankcase. Middle throw worn badly. Will a 445 crankcase interchange?
R.D.F.
02-11-2007 19:22:23
The crankshafts are interchangeable, don"t worry about the spiral seal surface. We build many of these engines and always use a lip seal with our own modification, never had a leak yet. We stock both seal styles as well the mods. needed for a conversion. Dale
rpllr
02-11-2007 19:13:25
Are you looking for a crank for a 445? I just took one out of a 445 crankcase. where are you located?
Chuck S.
02-11-2007 11:53:46
Yes it is the same.
T.R.K.
02-11-2007 12:09:29
 Re: 445 Crankshaft in reply to Chuck S., 02-11-2007 11:53:46
One thing to be aware of on those cranks: Some have a spiral groove in the rear main seal area. Those must use the felt rear main seal. Those without the groove can use a regular rubber lip-type seal.
