Minneapolis Moline Tractors Discussion Forum
1957 MM I hi,lo sprag?
Hal Westerlund
02-11-2007 07:46:05
Hi, I am new to thinking of splitting tractors apart. Any tips on replacing the sprag/rollers on a 335???/ any clues on how many things fall out when you gets the halves seperating. (just nervous). Any sources for the parts to acomplish this job???
Thanks for your time
Hal
Chuck S.
02-11-2007 11:50:35
 Re: 1957 MM I hi,lo sprag? in reply to Hal Westerlund, 02-11-2007 07:46:05
Hal if you are new to spliting tractors be careful. Get you a copy of an IT shop manuel. The one thing they dont stress enough is to tie the at lever in high range before you remove the cover behind the through out bering.This cover has the bering slide made onto it. If you donot tie the A/T shift lever in high range when you remove the cover the high range clutches will fall out. This makes it harder to remove the shift forks. Be very careful Good Luck Ps Parts are still avable for this unit thru Agco
