Minneapolis Moline Tractors Discussion Forum
LP starting tips
davids
02-08-2007 16:47:28
Whats the proper/easiest way to start a U that on propane? Hard to start when cold but after warmed up just touch the key and she starts right up. Any help/hints are appreicated. Thanks, davids
Ken Majeski
02-12-2007 16:55:57
 Re: LP starting tips in reply to davids, 02-08-2007 16:47:28
Well.... I can tell you a problem that I had. The diaphram in the regulator had sagged and the primer Button / Solenoid was missing the nubbin in the center of the diaphram.... And No Start when Cold. So I took one of the Leather snap button things and put it under the screw that held the diaphram together. this made a larger target. This was about 3 years ago and it still starts Fine...
rpllr
02-09-2007 19:34:54
I have a jetstar on lp I start when its cold, and it helps if you stick a trouble light or a heat light close to the regulator for a while to warm it up enough to vaporize the fuel.
Glen in TX
02-09-2007 12:55:11
Many LP carbs don't have a choke but some LP converters had a primer button or electric solenoid primer hooked to a dash mounted push button. The primer is your choke on LP for cold starting aid. You usually don't need the primer in warm weather. Have your spark plugs gapped down to .015-.018 ? That is recommended spark plug gap for most any and all LP engines and they will idle smoother too. You are only starting on vapor right?
