Minneapolis Moline Tractors Discussion Forum
FM J Magneto
Molinegb
02-03-2007 07:04:55
Had a working mag and disassembled to clean and set points. Now I don't have any spark at cap.I timed the metal mag gear with the beveled tooth lined up with the C mark on the fibre gear on the cap. I have spark at the coil but nothing coming out of cap.Any ideas?
T.R.K.
02-03-2007 17:11:52
 Re: FM J Magneto in reply to Molinegb, 02-03-2007 07:04:55
I guess you put the rotor button back in. I am also guessing you put the copper rod back in that contacts the tab on the coil.
I am thinking they had two marks on the fiber gear. You use one for Clockwise and the other for counter clockwise rotation.
You didn't say what model it was, but I think Rs and Zs are counter clockwise rotation.
I have also seen the shaft with the fiber gear seize up in the cap and the gear spin on the shaft. (It drove me nuts-It would pop occasionally but not start.)
These are just some thoughts. Hope it helps.
