Minneapolis Moline Tractors Discussion Forum
u with magneto are gears the same as distributor
polson
01-29-2007 17:55:56
can you put a distributor on a u that had a magneto? are the gears differentthanks Paul
Ill John
01-29-2007 19:54:54
 Re: u with magneto are gears the same as distribu in reply to polson, 01-29-2007 17:55:56
Someone will correct me if I'm wrong, but the mag mounts on the back of the timming cover, where the hyd pump would mount, the dist mounts on the top of that timming cover. If you look inside where the dist would mount and see a sprial cut gear, the dist will work there. If no sprial cut gear, you need to change the waterpump shaft or one with the cut gear.
