Minneapolis Moline Tractors Discussion Forum
Carburetor kit needed for MM UDLX
R.L. Smith
01-29-2007 16:34:38
A close friend has been working on his MM UDLX for about four years. He's close to starting it up. I have his carb and would like to find a carb re-build kit for it, and if possible a better float. The carburetor is a Schebler TTX 17. Do any of you guys know where I could find these parts? If so, please E-mail me, any and all help is greatly appreciated.
Joshua Ratliff
01-31-2007 21:04:32
 Re: Carburetor kit needed for MM UDLX in reply to R.L. Smith, 01-29-2007 16:34:38
as every othe MM guy is thinking right now "someday I hope I'm trying to find a carb kit for my UDLX"
R.L. Smith
02-01-2007 05:27:39
 Re: Carburetor kit needed for MM UDLX in reply to Joshua Ratliff, 01-31-2007 21:04:32
Thanks for the help guys.
However, still no float. Getting to talk with lots of good knowlegable people about this carburetor and "rare" tractor. When my friend sent the carb. insured, I knew it was a "hard-to-find" item. I had no idea, I'm just a carb rebuilder. I now know that a float from a Schebler TTX 18 will fit the 17 carb. I am willing to buy good used float. Please keep the info coming, I really need a float.
Thank you.
JLM
02-01-2007 08:33:15
 Re: Carburetor kit needed for MM UDLX in reply to R.L. Smith, 02-01-2007 05:27:39
Several years ago a friend who is an excellent airline mechanic demonstrated to me the skill to completely reman a float. He separated it at the seam into two halves, soldered many pinholes, built two new stems and soldered them on. He probably used two million dollars of equiqment to test and calibrate it during his lunch hour at the jetbase but I can only speculate. If you know of such a person your old float can be repaired. Never throw anything away or give up on it.There are people out there who can fix it. Good luck.
Jerry Grant
01-31-2007 09:38:01
R. L. Smith: Another excellent source is Motec Engineering. They have many new parts including wire harnesses. They also rebuild carburetors, goveners and distributors. There phone number is 765-963-6628 Jerry Grant
JLM
01-30-2007 08:48:59
Call these guys. 573-392-7378 (8-5 Mon-Thurs central time).
But first check out their web site at: thecarburetorshop.com
