Minneapolis Moline Tractors Discussion Forum
1962 MM Air Cleaner
Ralph S.
01-18-2007 18:46:59
I am looking for the air cleaner assembly for my 1962 MM garden tractor. It has a 7 hp. Kohler engine. Any leads would be appreciated.
563-570-4077
Ill John
01-18-2007 20:32:57
 Re: 1962 MM Air Cleaner in reply to Ralph S., 01-18-2007 18:46:59
What part of the world are you located in? Should be someone close to you with one. I've got some. If you're looking only for the paper filter, NAPA or any small engine shop can get them, most s/e shops might have the complete filter. Pretty common.
T.R.K.
01-20-2007 08:42:56
 Re: 1962 MM Air Cleaner in reply to Ill John, 01-18-2007 20:32:57
Actually, that particular air cleaner housing is not common to the Kohlers I've seen here in NC. (I've been looking for one myself for my '62-63 moline mower.) The more common air cleaners are mounted vertically on the back of the carburetor. They have the screw holes to fasten them directly to the carburetor. I only see that adapter elbow on Jacobsen mowers. It has to be that particular adapter elbow to clear the battery box. If you have the adapter elbow, some of the early John Deere mowers look like they had the correct air cleaner housing, they just use a different adapter elbow. The correct air cleaner has only one 1/4 inch bolt through the center that clamps the top, element and bottom to the adapter elbow, kinda like the old car air cleaners.
