Minneapolis Moline Tractors Discussion Forum
utu gen bracket
paul johnson
01-15-2007 16:52:55
I need a picture so I know how it mounts, help
thanks Paul
T.R.K.
01-17-2007 06:52:13
 Re: utu gen bracket in reply to paul johnson, 01-15-2007 16:52:55
There are at least 2 brackets. Earlier brackets use 2 of the front cover bolts and wrap around the right front side of the engine. I can't send you a pic. but which 2 cover bolts should be obvious when you hold the bracket up there.
Later brackets mount to two 3/8" holes in the side of the engine block. Like Kevin M. says, the bracket should angle upwards to the generator mount holes.
Kevin Moschenrose
01-15-2007 22:22:58
Paul, If you are using a factory orignal bracket there is only one way it will go onto the tractor that makes the generator and fan belt usable. The bolt holes for the generator are pointed at an angle upward.
