Minneapolis Moline Tractors Discussion Forum
lp over gas
towboatt
01-14-2007 18:11:54
JUST GOT A GV1 ON LP AND WANT TO USE THE TRACTOR FOR PULLING.NEED SOME ADVICE ABOUT CHANGING TO GAS OR LEAVING IT ON LP.WHAT WOULD BE BEST FOR PULLING? ALSO WOULD LIKE TO CUT SOME WEIGHT OFF. NEED TO CHANGE THE REAR WHEELS AND HUBS TO PRESS STEEL. ANY BODY HAVE SOME GOOD IDERS OR EXPERIENCE IN DOING THAT? THANKS TONY
willywonka2
01-14-2007 22:42:57
 Re: lp over gas in reply to towboatt, 01-14-2007 18:11:54
I dont know what your rules let you do but i would stay with lp, shed off the stock lp tank and put a fork lift cylinder on it. that will lighten it up, every know and then you will run across a set of hubs that some guy builds on here in the classifieds for the 6 spline axle. take off the fenders and unnecessary equipment like the hyd tank under the seat, ditch the cast front axle and make a light one out of tubing. You could put an aluminum trans top on, fiberglass radiator tanks, fiberglass oil pan, and the list goes on. Just a few ideas for you Willy
willywonka2
01-14-2007 22:45:31
 Re: lp over gas in reply to willywonka2, 01-14-2007 22:42:57
Oh i was gonna ask who you tow boatin for?
TOWBOATT
01-15-2007 05:29:48
 Re: lp over gas in reply to willywonka2, 01-14-2007 22:45:31
I WORK FOR SOUTHERN TOWING CO.MEMPHIS ,TENN .
SOUTHERN IS A BARGE LINE. PUSH AMONINA , LIQUID
CARGO AND COAL ON THE MISSISSIPPI,OHIO AND INTERCOASTAL. I WORK OUT OF THE SHOP HERE IN MEMPHIS. THANK YOU FOR THE IMFO. TONY CONDY
willywonka2
01-15-2007 18:39:03
 Re: lp over gas in reply to TOWBOATT, 01-15-2007 05:29:48
reason i asked im a river rat too workin 4 blessie marine most of the time on their mains and gens.everynow and then for ACBL and ingram
