Minneapolis Moline Tractors Discussion Forum
UBD battery polarity
pvia
01-12-2007 07:52:47
Hello, my UBD has a 12 volt system connected as a positive ground. Is the polarity correct? How do you jump start a positive ground system with a negative ground system? Thanks, Phil
pvia
01-12-2007 08:37:36
 Re: UBD battery polarity in reply to pvia, 01-12-2007 07:52:47
Thank you for the info Bob. Phil
Bob
01-12-2007 08:13:34
I would ASSUME (+) ground is correct.
To jump start, you simply match up the booster cables to the markings next to the battery posts,
RED clamp to the terminal marked (+) at each battery, BLACK clamp to the terminal marked (-) at each battery.
Do not allow the bumper or any other metal parts of the vehicle used for "jumping" to contact any metal parts of the tractor being "jumped".
Bob
01-12-2007 08:13:27
