Minneapolis Moline Tractors Discussion Forum
M602 3 point
iowa dave
01-08-2007 15:17:46
Will a 3 point off of a G-1000 work on a M602. I have one located and the first look says yes. I'd rather learn from other's experience where possible. Thanks, Dave
iowa dave
01-09-2007 15:50:48
 Re: M602 3 point in reply to iowa dave, 01-08-2007 15:17:46
Thanks for the input. I went for it but another guy wanted it worse than I did. I've got an E-2 system on it with an after market 3 point. I'll just stick with it for awhile longer.
Harrold Rhodes
01-09-2007 08:21:59
The complete Hyd lift is much larger on 1000. I think the main pull arms are the same. The lift arms are different but I think will work
joho
01-09-2007 02:27:01
No, The three point looks similar but the G-1000 three point is much bigger than the M602 three point.
schrocky
01-08-2007 15:22:07
I cannot answer your ? however I have both tractors here and it looks to me like everything in the back is the same but the G1000 uses a different style hyd pump. If you run into trouble let me know we have a 602 parts tractor with 3 pt
Alan K
01-08-2007 21:21:06
 Re: M602 3 point in reply to schrocky, 01-08-2007 15:22:07
I might be interested in a part from your M602. Send me an email if you would.
