Minneapolis Moline Tractors Discussion Forum
UTS magneto
john eitel
01-06-2007 15:03:05
Does the mag need battery voltage to work or is it self energized.
Glen in TX
01-09-2007 22:07:00
 Re: UTS magneto in reply to john eitel, 01-06-2007 15:03:05
Molinegb is talking about the Wico XB battery distributor. It has a fibre board resistor on one side with connection for battery wire. Yes magnetos produce their own power hence the name. There were Wico XH and C magnetos and other brand magnetos. You should NEVER should have battery voltage connected to a magneto as it will fry the coil, condenser, points and possibly ruin the magnet. The terminal you see on a magneto is for a ground kill switch only.
Molinegb
01-08-2007 05:06:55
I had a 39 MM U that had a Wico mag on it. It turned out it was a distributor that looked like a mag. It required voltage supply.
xenical
01-18-2007 10:49:18
 xenical in reply to Molinegb, 01-08-2007 05:06:55
"g12208v-g5sg5m5-tw6qf8b8-3
BMG1
01-06-2007 16:36:25
John,
Magnetos do not need battery voltage to function. They create their own electricity for spark. The only wire to a magneto is a kill wire to shut off the engine.
There were some distributors made that look similar to magnetos but it is unlikely that you have a distributor.
Brian
Nebraska Kirk
01-06-2007 16:33:24
Magnetos generate their own electrical current.
