Minneapolis Moline Tractors Discussion Forum
External hydraulic Hook Up
KCTractors
01-06-2007 12:01:51
I have a M-Moline 602 with a loader on it. I want to by-pass the tractors hydraulic control-valves and use a external 2 spool valve to operate the loader. Anybody that could send me pictures how they tee-ed off the pump and returned to the pump, and what kind of valve they used would be appreciated.
ILL John
01-07-2007 14:42:45
 Re: External hydraulic Hook Up in reply to KCTractors, 01-06-2007 12:01:51
This may be hard to follow, but I've got a Big Mo 400 with a loader, the guy before me did it like this. On the loader BUCKET control, he tee'd both lines going to the bucket, installed 1/4 turn shutoff valves, ran the remotes from the tees. To use the remotes, put the bucket where you want it to remain, close the valves, the power is then diverted to the remotes. It's the easiest way, as well as the cheapest, to use remotes when the loader has all the valves on the tractor tied up. You can email me at grandfieldfarm at peoplepc dot com, use a MM subject or it will get deleted. Thanks, John
KCTractors
01-07-2007 17:24:36
 Re: External hydraulic Hook Up in reply to ILL John, 01-07-2007 14:42:45
The reason I want to do this, is to speed up the use of the loader. I was told that this would make the loader work alot faster.
