Minneapolis Moline Tractors Discussion Forum
Timing with a Roosa master pump on an MF95
MPT
01-02-2007 22:37:43
I'm having a little trouble timing a MF 95 with a Roosa Master inj. pump of a G706. The shop went through the pump and injectors. I made no corrections to the pump and am timing according to MF 95 specs.Any help would be greatly appreciated
MPT
01-03-2007 10:22:46
 Re: Timing with a Roosa master pump on an MF95 in reply to MPT, 01-02-2007 22:37:43
Thanks Curt, maybe I'm 180 degrees out from TDC #1, how would I verify when I'm at TDC with #1 cylinder? Thanks in advance
Captainhookerus
01-04-2007 10:53:41
 Re: Timing with a Roosa master pump on an MF95 in reply to MPT, 01-03-2007 10:22:46
Depending who has worked on this tractor in the past the fly wheel may not be installed in the correct position. Can be installed in six different ways. Remove number five and six valve cover and roll engine counter clockwise if you were setting in the seat. Then watch number six intake valve (next to last) and as soon as pushrod just starts to come up you will be very close to TDC number 1. Also MM engines with Rosa
pumps were timed at end of injection.
Jake Winn
01-03-2007 21:15:48
The best way to check is remove the front rocker arm cover and check the pushrods for #1 cylinder. If its #1 tdc, they should both be loose. If its #6, they will be tight.
Good luck.
Curt Cooke
01-03-2007 06:52:57
What kind of trouble are you having? They are pretty simple. Get the engine on or about TDC No.1 (maybe 11 degress before), remove the little window on the side of the pump and get the lines lined up and install. You may have to move it a toothe forward or back but when you're done, with the flywheel a few degrees advance of TDC No.1, the lines behind the window of that pump must be lined up.
