Minneapolis Moline Tractors Discussion Forum
Reversing 12-Volt Conversion
JKC
12-26-2006 08:53:00
I have a 1948 MM RTU. Guy I bought it from had converted it (somewhat) to 12 volts system....12 volt battery to a modified 6 volt system (generator still there, voltage regulator gone, no alternator, etc. Please forgive my ignorance here, but I would like to reverse this "conversion" back to a 6-volt system with all the necessary components in-place. Would someone be kind enough to spell-out for me what I need to change-back? Battery is obvious, what about electrical coil, proper wiring to voltage regulator/generator, etc. Anything need to be done to the distributor, points, condenser, etc.? Any help would be very much appreciated. Thank you.
Roger H MI
12-26-2006 15:51:56
 Re: Reversing 12-Volt Conversion in reply to JKC, 12-26-2006 08:53:00
It sounds like you have all the componnets there,check your generator to see if you have three brushes. If you do you can keep your 12v battery or adjust for six volt with either positive or negitive ground. You will have to get a voltage regulator. Churubusco auto electric out of Indiana sells electronic one that mount on top of the generator like the original ones, nice unit. There telephone number is 260-693-2439 they also have generators.
