Minneapolis Moline Tractors Discussion Forum
Brake drums for an R
MM-R
12-20-2006 12:47:17
A friend needs brake drums for an R, are they that hard to find? I know nothing else about why the drums are "bad". Have tried a couple of the 'usual' suppliers with nothing. Any advice/direction would be appreciated! This tractor was sold new by a great-uncle of mine to a neighbor, that's where I got involved. Thanks!
MM-R
12-21-2006 15:35:04
 Re: Brake drums for an R in reply to MM-R, 12-20-2006 12:47:17
THANKS to BMG1 and UTURN! I haven't put eyes on it yet and I need to talk directly with the owner, probably after the Holidays before I'll see him. When I sort out the problem, I'll post back. Thanks again, I appreciate the help!
T.R.K.
12-21-2006 17:44:33
 Re: Brake drums for an R in reply to MM-R, 12-21-2006 15:35:04
He probably needs linings for his brake disks for his R. If that is the case, he needs to know if it is early style or late style. The early design used 1 disk on each side and the late style used 2 disks on each side with an actuator assembly between the disks.
The change was in about 1948, There were some 'transition' models that used the early 6 spline axle with the later 2 disk arrangement. Later 2 disk models used an axle with many more splines and the brake disks do not interchange, but the linings are the same as far as I know.
Welter's # is 417-489-6496. Baucom is 1-800-658-2309. The 'free' phone call not necessarily 'free' as Baucom ships only COD which used to be automatic extra $5 and is probably more now.
MM-R
12-22-2006 06:52:06
 Re: Brake drums for an R in reply to T.R.K., 12-21-2006 17:44:33
THANKS! to T.R.K., that info will help immensely when I get it sorted out. Thanks again!
BMG1
12-20-2006 16:16:38
All Moline R models use disc brakes. Brake drums are not being reproduced for any of the letter series Molines that did use them (Z,U,G). You can just re-line the existing brake discs at a clutch and brake shop. Are you sure its a model R? The ZT looks very similar to the R but they don't share any parts except for a few engine and sheet metal parts.
Brian
UTURN
12-20-2006 13:24:58
Try Welters farm supply in Verona, MO. or
Balcom Implament, Fairmont MN L A
