Minneapolis Moline Tractors Discussion Forum
GBD injection pump
Nebraska
12-19-2006 21:32:41
I have a neighbor looking for an injection pump for a GBD. It has the stock 425 motor. He said it is a American Bosch model PSB. He said that the original is in the repair shop and needs a new head. He told me that it is going to cost more to fix than he feels the tractor is worth. I told him I would check on here to see if anyone would have one that wouldn't cost an arm and a leg. Thanks for any help.
Thanks
Nebraska
Nebraska
12-21-2006 17:54:16
 Re: GBD injection pump in reply to Nebraska, 12-19-2006 21:32:41
Thanks a bunch guys! Thats great stuff to know for future reference. I will relay the info on to my neighbor. I hope you all have a Merry Christmas.
Thanks Nebraska
Nebraska
12-20-2006 07:20:09
Sorry guys, I guess I should have said, he wants to stick with the bosch pump and not do a change over. I think he told me that it was going to be around a 1000 dollars to get his pump fixed. As far as the complete model number on the pump I will see if I can get it from him.
Thanks Nebraska
Captainhookerus
12-20-2006 09:16:26
 Re: GBD injection pump in reply to Nebraska, 12-20-2006 07:20:09
Will he take a $1000.00 for the tractor?
J Schwiebert
12-20-2006 09:02:18
What is the problem with his pump?
Nebraska
12-20-2006 11:51:28
 Re: GBD injection pump in reply to J Schwiebert, 12-20-2006 09:02:18
J Schwiebert, he told me that the repair shop said that the head on the pump was bad, as far as what is wrong with the head, he doesn't know. Is there a lot that can go wrong with the head? The repair shop said that they found a head on the east coast somewhere. Are they that hard to find that they cost that much?
Thanks
Nebraska
BMG1
12-20-2006 16:24:34
 Re: GBD injection pump in reply to Nebraska, 12-20-2006 11:51:28
Nebraska,
It is not uncommon to spend that much to rebuild a PSB pump if the head is bad. I've seen shops charge as much as $1500. Parts are getting quite hard to find for the single plunger PSB pumps. I'm no expert but I'm told the single plunger can stick from sitting or other reasons and if you crank over the engine damage will occur inside the pump. Just a word of warning if you're trying to start that PSB equipped diesel tractor that has been sitting for awhile.
Brian
Nebraska
12-20-2006 18:32:44
 Re: GBD injection pump in reply to BMG1, 12-20-2006 16:24:34
BMG1, what can be done to prevent this from happening again (if he gets it fixed)? Is it ok to pull the head off and inspect things before trying to start? What other tractors used this pump?
Thanks Nebraska
J Schwiebert
12-21-2006 17:53:31
 Re: GBD injection pump in reply to Nebraska, 12-20-2006 18:32:44
How hard are you going to work this tractor? Do you have any friends with a Case 500 Diesel? J.
J Schwiebert
12-21-2006 17:11:10
I did an article for the Oliver collectors and I mentioned if the tractor has set for some time pumm the control unit off and slip a 6 inch screw drive in the control slot. Put about one fing effort on the handle if the control unit does not move don't try to start it. Also if you do not plan to run it for a while put diesel test oil in the tank and run it on that before you shut it off. More questions?
BMG1
12-21-2006 15:57:58
Nebraska,
I don't have much of a recommendation to prevent this other than keep clean fresh fuel in it and run it on a regular basis. Diesel will varnish the insides of a pump in time causing components to stick and bind. The PSB pump is not too difficult to work on but you should read up on its disassembly procedure before attempting to remove any parts of it. Some Oliver parts books show a good breakdown and their shop manuals do a good job of describing repair procedures.
Early 6 cylinder Oliver and Case diesel tractors used the PSB pump. MM switched from the PSB to the Roosa midway through 6 cylinder GVI diesel production run. I'm not sure if it is the same part number and rotary head part but most of the parts should interchange. The rotary head will be unique depending on the specific engine fuel requirements. Your diesel shop should be able to tell you what other tractors used the same model pump.
Brian
J Schwiebert
12-20-2006 02:56:48
Do you have the complete model number for the PSB pump? Remember on the Roosa you will need fuel lines and a change in the drive gears too. J.
Nebraska
12-20-2006 18:37:07
 Re: GBD injection pump in reply to J Schwiebert, 12-20-2006 02:56:48
J Schwiebert, I did get the complete model number from the guy. PSB6A80D3831A
Thanks
Nebraska
wonder blitz
12-20-2006 04:54:10
You have to change the pump drive also. Which means you have to remove the front of the tractor to remove the timing cover. How much to fix the PSB pump?
ejr-IA.
12-19-2006 21:42:59
Bet you could find a Roosa Master pump off a G 706 or Massey 97 fairly easy this would be a good update.
