Minneapolis Moline Tractors Discussion Forum
MM Steel Wheels
Molinegb
12-09-2006 05:20:00
I was trying to sort out what steel wheels fit.I have a set of Z rears with splined hub and I think they only fit a Z standard. I was wondering what would fit the front?
Will steel wheels off a FTA fit early GT or later GTA?
I have a chance to pick up two sets of steel for a U. Which hub configuration do they fit on?
Curtis Rink
12-12-2006 09:46:29
 Re: MM Steel Wheels in reply to Molinegb, 12-09-2006 05:20:00
There are two sizes of rear steel for a "U". One fits the cast center for 32" rim and the other fits the cast center for 36" or 38" rim. You will need to measure the bolt pattern distances or place it next to a cast center to know which you have.
Jake Winn
12-11-2006 10:17:47
The spline hubs are for the JTS or ZTS. The steel wheels for a row crop have the clamp/keyway style. The fronts are the same between a rowcrop and standard.
The only steel wheels I have seen for a U bolt to the cast center where the rim clamps would go on rubber tired tractors.
If you would like to sell a set of the U steel, let me know. Thanks. Jake
