Minneapolis Moline Tractors Discussion Forum
1953 ZB rim
Moline M.
12-07-2006 05:43:41
Can you take the outer rear rim from a ZB that has a big rusted out spot in it and cut the rivets off and replace the outer rim with a new one? (11/38 size) Also were can you get one ? Thank"s
Alan K
12-07-2006 22:31:20
 Re: 1953 ZB rim in reply to Moline M., 12-07-2006 05:43:41
If you can find an early Model A JD they use the same rim as the ZA and ZB's did. If you look just about a foot to the left from the valve stem on the dish part you will find the number JD1260R. Hope this helps.
T.R.K.
12-07-2006 06:48:28
I did it on an R. Miller Tire sells the replacement rims. They have a website, just do a search for Miller Tire.
