Ken-in-K
12-08-2006 09:05:08
Re: MM 335U in reply to rpllr, 12-06-2006 18:14:11
The sale price is 2500.00 condition average, repairs done , Complete new radiator core, O/H starter, new clutch plate rear eng and trans seals, new battery, left brake new friction plates and oil seal, right brake needs friction plates and oil seal, O/H 3pt hydraulic pump bearings and seals, Carburettor pro rebuild, new muffler, New plugs ign wires coil cap and rotor, The adjusting link on the left lifting arms (3pt) broke and has been replaced by JD link, The whole tractor is painted red wrong color, The sheet metal is average worst part the hood has a dent Oil pump shows psi 40 never varies, New thermostat located in the top radiator hose, New temperature gauge and engine sender , Steering not hyd but easy to turn, New left rear tire rim, Tires rib on front 40% and 50% on back, Converted to 12V, The front lights are off the tractor need Halogen lenses and wiring, I am located in Edmonton KY can email questions to [email protected] Thanks for looking.
