Minneapolis Moline Tractors Discussion Forum
I Need RE101-A block from R or Z
Len
12-05-2006 17:40:43
I purchased a nice looking RTN from an estate. It blows a lot of water (coolant) into #4 cylinder. Took the head off, can't see anything, put it back together with a new head gasket. Are decent R101-A blocks available? How much do they cost? I just want a running, nice looking tractor: not going to use it as a puller and don't want to spend a fortune on it. Suggestions? Anyone have a good block to sell? Know where one is?
ILL John
12-05-2006 20:20:33
 Re: I Need RE101-A block from R or Z in reply to Len , 12-05-2006 17:40:43
Len, Where are you? It makes a difference when I decide to part with something as heavy as the RE101A block. Thanks, John
Len
12-06-2006 20:26:17
 Re: I Need RE101-A block from R or Z in reply to ILL John, 12-05-2006 20:20:33
I'm near Portland Oregon.
awaller
12-06-2006 06:37:56
Len, you also need to make sure that your pistons are standard, alot of these blocks available have been bored for oversize. I would see if you can find a slavage yard that has a set of block with pistons siezed in them. Most times the pistons can be work out of them with time and patience. Ask Ethan Berry about this as I bought a set of blocks from him last winter and had great luck with them. He had a situation where he had a set of blocks with the pistons stuck and he managed to get them worked free.
