Minneapolis Moline Tractors Discussion Forum
1947 MM R Points, etc.
JKC
11-18-2006 05:09:59
I need to replace the points, condenser and coil on my 1947 MM R. Can anybody tell me what part numbers to look for at the auto supply stores? CarQuest, AutoZone, Napa, O'Reiley's are my choices.
Thank you very much.
ILL John
11-19-2006 19:38:24
 Re: 1947 MM R Points, etc. in reply to JKC, 11-18-2006 05:09:59
The NAPA Echlin # for the points, CS763A, cond, RR176
CENTAUR
11-18-2006 08:23:21
First identify the make & model of your distributor.By model I mean number of the distributor.It will be a AUTOLITE or a DELCO-REMY & I doubt it could be anything else. Old points can be made like new quite often by touching the points against the side of a fine grinding wheel.It will leave the point looking as smooth as chrome.YOU W[LL HAVE TO TAKE THE POINTS APART TO DO THIS.YOU MIGHT BE ABLE TO DO THE SAME THING WITH A HIGH SPEED TOOL SUCH AS A DIE GRINDER OR EVEN DREMEL TYPE TOOL.The above worked real well for me on the side of valve grinding wheel.Forgive me for the above type.My shift key has went into reverse.CENTAUR
