Minneapolis Moline Tractors Discussion Forum
445 3 point
jj445mm
11-11-2006 07:29:51
I have a 445 and the 3 point dosnt go up, the power steerign works but not as good as i think it should. is there a place to check the hydraulic oil or is something else wrong.
Kevin Moschenrose
11-11-2006 09:19:54
 Re: 445 3 point in reply to jj445mm, 11-11-2006 07:29:51
Under the seat where the two draft controls are at remove the four screws and lift the control levers straight up. But make sure it it nice and clean there first because this is straight in to the system. The oil level should be just over top of the valves and controls on the inside or about an 1 1/2" below the the cover. When you replace the controls replace with a new cork gasket because silicone and hydraulics don't play well together. I am guessing your system is extremely low on fluid.
