Minneapolis Moline Tractors Discussion Forum
working on 335, have questions
Dale Hollen
11-04-2006 05:17:45
Thanks to Mark, rpllr & T.R.K for response last time. If I put a 206 crank in a 335 what do I have to change in the 335? Rear bearing housing, ft & rear seal, flywheel, timing gear, ft pulley, rod, piston, govenor assem????? ? Hate to be longwinded but kind of dumb when you start changing things. Thanks for help!
Dale
JK2
11-04-2006 07:08:33
 Re: working on 335, have questions in reply to Dale Hollen, 11-04-2006 05:17:45
To put a 206 crank in a 335, you must change the crank and the rods to 206 rods. The pistons, bearings and rear bearing support are the same. If the crank you are using is an early one with the spiral groove at the rear seal, you will need to use a felt type rear seal that was designed to seal on that crank (the same as the original 335 seal). If the crank doesn't have the spiral on the rear seal surface, you can use the rear seal from a JetStar3. You will be raising the compression ratio some & if you bore it much, that could cause pre-ignition if lugging it while running regular gas. John
