Minneapolis Moline Tractors Discussion Forum
445 Governor stuck?
Mr. Jeffries
10-31-2006 07:43:47
Hello gentlemen,
Our ag class has been working on a 445 utility for awhile and it runs really good. However, the governor must not be working at all because if you pull the throttle back at all, it will "race" until you release the throttle back to idle. Does anyone have any ideas as to where we might start to look for the problem? I"m guessing the weights are stuck on the governor. How hard will rebuilding the governor be? We don"t have a manual and are looking for your help.
Thanks in advance,
Jared Jeffries
TRK
11-02-2006 07:28:13
 Re: 445 Governor stuck? in reply to Mr. Jeffries, 10-31-2006 07:43:47
I had to do this on an engine a while back.
1. there should be no springs from the engine block to any part of the governor linkage. The only spring should be the spring that goes between the rod from the hand throttle to the governor arm. (An adjustable pin runs up through it.)I just said this because sometimes extra springs are added.
2. Try disconnecting the link from the carburetor to the governor arm. have a helper hold the carburetor throttle shaft closed and start the engine. you should feel resistance when you pull back toward the rear on the governor arm coming out the side of the engine. If there is no resistance, the fork inside is either loose or broken. Or something is wrong with the flyweight assembly.
3. If you feel resistance, Hold the carb link up to the hole in the governor arm still running. Keep enough pressure on the governor arm so you can tell the fork is up against the flyweight assembly. How do the lengths in holes compare and is the pivot in the governor arm free? Adjust and re-install the carb link about 1/4-1/2 hole short (I think: What you are trying to do is get the governor to still have a bit of pressure on the carburetor throttle when its at idle.)
Harrold Rhodes
11-01-2006 12:24:18
Try putting a half of a hole of pre-load at full throttle on govenor linkage. You might be lucky
MM 445
11-01-2006 05:52:50
I suggest you get a manual and look at the adjustment procedure for governor. I can not quote the adjustment prrocedure without one here in front of me. If you are lucky, you just need to adjust the rod length or spring tension.
If you need to get into the governor, you will need to pull the front bulster, damper pulley and the seal cover on the crank. The governor sits directly behind that cover. there is a single set screw holding a fork on the governor lever. Remove the fork from the lever and everything should pull out easily.
