Minneapolis Moline Tractors Discussion Forum
4 3/4 Bore M W Piston Clearance Question (403)
pullum
10-24-2006 21:08:16
I am going to bore out a 403 (G) engine to 4 3/4" using some nice-looking used M & W pistons. I need to know what the piston clearance in the bore should be so I can let my machine man know. I don't want it too tight and locking up on me! I had Total-Seal rings made for them if that makes a difference. I know that that is a common overbore and thought someone would know. Thanks ahead of time. LW or anyone?
Sorghum head
10-25-2006 19:18:58
 Re: 4 3/4 Bore M W Piston Clearance Question (403 in reply to pullum, 10-24-2006 21:08:16
You would need 8 thousands on new pistons maybe about the same on your used pistons. You probably need to mike them to find out the sise of them and bore 8 thousand bigger. Any less clearance and you will run a great risk of seizing and scouring the pistons and walls. Hope this helps.
pullum
10-26-2006 00:56:03
 Re: 4 3/4 Bore M W Piston Clearance Question (403 in reply to Sorghum head, 10-25-2006 19:18:58
It sure does help! Thank you very much!
